Highlighted
Ice maker help need help
I have a samsung gallery refrigerator model number fpbs2777rfo that the fresh food ice maker broke on.  I replaced the ice maker and it worked great for enough time to fill the bin then it quit. Thinking the replacement went bad I swapped it out and the same thing happened again. One full bin then it quit. Obviously the replacement unit is good but something else is shutting it down.... what do I check next?
1 REPLY 1
Highlighted
Re: Ice maker help need help
Hello, the model code that you provide is for a Frigidaire French Door Refrigerator. I would recommend reaching out to Frigidaire's customer service concerning this.
