Re: Ice maker is frosted over
JUMP TO SOLUTION
For assistance, send us a private message to the link below with your serial number.
http://bit.ly/2hQXHNu
userhVzkP8HBHg
U r gettin air it is oxidizing that is y ur getting ice b...
JUMP TO SOLUTION
U r gettin air it is oxidizing that is y ur getting ice build up
userNz6RRgI9QL
JUMP TO SOLUTION
We still have our icemaker freezing up. Samsung knows there is a problem and has class action lawsuits for this matter. I'll never buy another fridge from Samsung.
userY8ATsel2HU
JUMP TO SOLUTION
Same problem as everyone else here has reported.  Ice maker has never been stellar, but it worked....up until last week....now, frosted over and no ice.  Defrosted, hair dryer, repeated, etc.  PM'd one of the mods and will see what gets suggested.  Overall, such a disappointing situation for all.
userSj7JIh1zhU
JUMP TO SOLUTION
I’m having the same issue. I've had my refrigerator since 2018 and never had an issue until this week. Ice maker is frozen.... thawed it out and lasted about a week before more frost.
JUMP TO SOLUTION
I can see how this may be frustrating. Can you give these troubleshooting steps a try?
  1.  When was the last time you changed your water filter?
  2. After you defrost the ice maker, have you tried to reset the ice maker?
  3. Is the unit leveled
  4.  https://www.samsung.com/us/support/answer/ANS00062321/
user0JAsUbxIJB
JUMP TO SOLUTION
I've had the same issue for six years. its a defect in the refrigerator design. There is a class action lawsuit against Samsung for the ice maker. I filed a complaint with the New Jersey BBB and, although Samsung called me, they sent me to four different agents and kept me on hold for over an hour. There was no follow up and no one offered a solution. Apparently, they don't care enough about their customers to do the right thing. I wish you luck.
userYywYYvavEQ
JUMP TO SOLUTION
My fridge model #RF25HMED3SR
ice maker keeps freezing and accumulating lots of ice. I will scrape the ice, it works for 7-10 days then freezes again. Help! Is it the seal?
JUMP TO SOLUTION
How long have you had your fridge? Do you see any seal damages anywhere?
Mike_in_Waldo
JUMP TO SOLUTION
Get used to it.  It is a design deffect, which they will not admit to.  I have have this blasted box for four years, and every month you have to defrost to get ice.  Then, its mushy ice at best!  There is a class action suit going on right now, let's see what happens.  Samsung needs to stand behind their machines AND customers.  Unfortunately, up till now, both are being left in the "cold".
