Ice maker light on - won't turn off
(Topic created: 06-02-2021 09:54 AM)
Michael-1257
Kitchen and Family Hub
I recently bought o home that has the Family Hub refrigerator Model # RF265BEAESR - with screen.  It's working fine so far, except for a small issue with the ice maker.  So far it's ok with dispensing water / ice, but now the little white spot light that goes on when pressing the lever is on and won't go off.  I've played with the switch, unplugged, etc... but so far it's staying on.  Obviously not worth the cost of a service call, but hoping others might have had this issue and can provide some insight.  Thanks much!
SamsungJam
I get how that could be a bit frustrating.  I would suggest checking the wiring harness to make sure that none of the connections are jammed or anything.  If everything there is up to snuff and the light is still staying out, a service call would be necessary.  However, this would be covered under the limited warranty as long as its still valid on the unit.
1 Reply
SamsungJam
