Highlighted
Ice maker not working - recall
JUMP TO SOLUTION
I went out and had a 3rd party company who is samsung authorized. He helped a customer before me and stated that our fridges were the exact same with the same issue on the ice maker. He said samsung covered the cost after she showed them her invoice. Is mine under the class action lawsuit? I paid $300 for them to come out and fix it today. Does anyone know how do I get my invoice covered like the other customer?
Model # F263BEAESG/AA
1 SOLUTION
Highlighted
Honored Contributor
Re: Ice maker not working - recall
JUMP TO SOLUTION
I'd be happy to look into this for you, mind sending me a private message here with your full model code and serial number?-->http://bit.ly/2igAXKH
20 REPLIES 20
Highlighted
Honored Contributor
JUMP TO SOLUTION
Highlighted
JUMP TO SOLUTION
Have the same issue, how can you resolve for me.
Highlighted
JUMP TO SOLUTION
Ice maker is broken.
Model #: RF263BEAEWW/AA
HELP!!
Highlighted
JUMP TO SOLUTION
I'm sorry to hear that, is the icemaker not producing ice?
Highlighted
JUMP TO SOLUTION
My ice maker is still making a terribly loud noise even after following suggestions per Samsung to fix it.   I'm wondering if my ice maker is part of the recall.  Model #RF23J9011SG
Highlighted
JUMP TO SOLUTION
Having same issue, how can Samsung resolve for me?
Model #  rf260beaesr
Highlighted
JUMP TO SOLUTION
To anyone experiencing this please send me your full model code and serial number via private message.
Highlighted
JUMP TO SOLUTION
Hello my ice maker is also broken, and we've defrosted and restarted numerous times. HELP, hot weather is here. Model Name RF263BEAEWW/AA Serial # <hidden>. Please advise how we get this ice maker fixed, or replace the fridge/freezer altogether.
Thanks.
Highlighted
JUMP TO SOLUTION
I bought a RF24FSEDB fridge with the exact same issues with my icemaker. Is there a recall to get it fixed? Thanks Ryan
