Highlighted
Ice makers not working and will not reset
JUMP TO SOLUTION
I have a model RF323TEDBSR where both ice makers have stop working.  The top one stopped a few months back because of frost issue which I defrosted and tried reset process a number of times, but I could never get the ice maker to start working again and it hasn't worked since.  The bottom one stopped working this week which I think was frost related (i.e., ice build up on top) so I had to defrost the bottom freezer.  After cleaning out the freezer I tried the do the reset process on the ice maker, but I don't think the button is doing anything as I'm not getting any response/feedback when I press and hold the reset button (i.e., no beep or action from the ice maker).  I have waited 24 hours to see if anything happens and still nothing.  This was the same experience I had on the top ice maker when I tried to reset it.  The water dispenser is working fine so I don't believe it is a water supply issue.  Am I missing something or it is possible I have two dead ice makers?  Any suggestions? Thanks
1 SOLUTION
Highlighted
Re: Ice makers not working and will not reset
JUMP TO SOLUTION
Please send me a private message with your model code and serial number.   http://bit.ly/2igAXKH
96 REPLIES 96
Highlighted
JUMP TO SOLUTION
Have you tried testing the ice maker without the water filer installed?
Highlighted
JUMP TO SOLUTION
I did removed the filter, but it did not seem to make a difference.
Highlighted
JUMP TO SOLUTION
And just to verify, the ice off light isn't illuminated, correct?
Highlighted
JUMP TO SOLUTION
Yes the "ice off" light for both ice makers are not on.  And the water dispenser is working.  I have tried the reset button on both ice makers, but am not sure what is suppose to happen after holding it for 10+ seconds.  Nothing appear to happen.
Highlighted
JUMP TO SOLUTION
Not even a beep or "ding" sound?
Highlighted
JUMP TO SOLUTION
I do not hear a beep or any type of sound (e.g., moving parts).
Highlighted
JUMP TO SOLUTION
If you could, please send a private message with the serial number.
Highlighted
JUMP TO SOLUTION
Could you let me know how I would send a PM? I don't see an option for this.
Highlighted
JUMP TO SOLUTION
http://bit.ly/2ihPL97
