Left knob on the electric range won’t fully turn off
(Topic created: 03-06-2023 10:09 AM)
Dana88
Kitchen and Family Hub
Left knob on the electric range won’t fully turn off, even in the off position. It doesn’t get hot, but the little knob light is on and the fan is on. One time it did get hot and started burning a pot, so now we make sure there is nothing on it or it’s a fire hazard. How can I fix this? Thanks so much, and would much appreciate your response soon if possible.
Samsung_Moderator
Hello there and thank you for reaching out to our Samsung Community. I completely understand the need to have the left knob fixed as stated. I was able to locate this resourceful information here- https://www.samsung.com/us/support/troubleshooting/TSG01001949/ for you to review as a possible resolution. We also recommend
contacting us directly using any contact method listed below for further assistance if needed:
Facebook- https://www.facebook.com/samsungsupport/
Twitter- https://twitter.com/SamsungSupport/
Instagram- https://www.instagram.com/samsungsupport/
or
Private Message by selecting any moderator and clicking on the chat option with your full model and serial number, I would love to assist you further with this issue, if possible.
1 Reply
Samsung_Moderator
or
