userMVql8tRheB
Leveling legs won't turn on Samsung RF28R7351SR fridge
I need to level my fridge as the wheels are on the floor, thus causing the doors to not be properly align and closed (alert that door is open). I read the manual, it said to use a flathead and insert it to the leveling leg and turn clockwise or counterclockwise. I've done this MANY times on other appliances, no issues. For some reason it does not turn on this fridge no matter how hard I try.
Am I doing something wrong?
b4608316dd3ff8724b02146d9291f1d61c071aa7-1.jpgf2650ef9931402a417f9d4978711bd763834f574-1.jpg
5 REPLIES 5
useruvDd9EOZwY
Re: Leveling legs won't turn on Samsung RF28R7351SR fridge
We are having the same problem. Were you able to figure it out?
userMVql8tRheB
No, I haven't done it yet. Someone elsewhere suggested you need to get something underneath the fridge to lift it up and then you can twist the leveling legs.
In order to solve this concern, you would have to contact a professional installation company. They would be able to assist you with this matter.
useruvDd9EOZwY
Thank you! Do you know if this is something that should have been done when the delivery happened? I paid for the installation service.
There is nothing specific I'm aware of, but leaving the unit and connecting the wiring harness is one of the main things that should have been handled.
