Limit door opening on French Door fridge, can this be done?
(Topic created: 12-20-2020 09:58 PM)
userLnTL982lyx
Kitchen and Family Hub
Because of the placement of our French door family hub fridge, I need to limit the doors to opening only 90 degrees. Is there any way to do that?
Not applicable
There is not a mechanism on the refrigerator to limit the door opening to 90 degrees.
userVctvS9QX7B
Hi. Did you find a solution? I'm looking  to do the same thing.
thanks
Not applicable
