Highlighted
Microwave Does Not Power On mg11h2020ct
This microwave is about 2 years old, bought brand new at Best Buy for over $200 and it no longer powers on.  I've tried multiple outlets and had the same result...the microwave will not turn on.  Two years of standard use then failure is unacceptable for such an expensive microwave.
help
3 REPLIES 3
Highlighted
Re: Microwave Does Not Power On mg11h2020ct
Does it make any sound at all? maybe a beep even though the light or anything doesn't work?
Highlighted
No nothing at all, completely dead.  Tested on several known working power outlets and nothing at all, not even a flicker of light or life.
Highlighted
Can you send me a private message with your serial number and zip code? I would like to review your case.http://bit.ly/2tCGnGK
