Highlighted
Microwave flashes random signals and fan starts by itself
I have a ME21K1070DG, ser. no. <hidden> microwave hat started flashing random numbers about 6 months ago along with "Press OK to Start".  When it first started I wuld just press cancel and it would be OK for a while.  The problem is becoming more consistent and the other  day the fan started by itself.  I now keep it unplugged when not in use.  I have seen numerous posts like this on the internet and was wondering if Samsung has suggested repairs for this problem.
3 REPLIES 3
Highlighted
Re: Microwave flashes random signals and fan starts by itself
Hello there. Is the light on? Is the table-turning? Place a cup of water in the unit, is it heating? Does the door close properly?
Highlighted
Yes, the microwave door closes properly and heats up stuff up.  I do need to keep it unplugged when not in use to avoid the sporatic displays and fan running on its own
Highlighted
This is going to require service. Please send your email address to this PM Link, and we will look in to service options for you.
