Highlighted
Model DW80M9550UG Dishwasher leaking
Model DW80M9550UG dishwasher has deleveoped a leak from the lower leaft corner of the door.  It doesn't leak the same amount every time.  Our son and wife has the same dishwasher model and it has developed the same issue.  Is there a known solution to this problem?
1 REPLY 1
Highlighted
Re: Model DW80M9550UG Dishwasher leaking
I'm sorry to hear that, you can try and check the seals around that area to see if there is any obstruction if there is not then this will require service please send me a private message with your full model and serial number to look into this further.
