Highlighted
Model # RF28K9380SR - showcase door not opening.
JUMP TO SOLUTION
my samsung refrigerator's (4 door french door) showcase door is stuck closed. It does not open - the latch seem to be loose.    Please advise regarding solution.   Thanks
1 SOLUTION
Highlighted
Re: Model # RF28K9380SR - showcase door not opening.
JUMP TO SOLUTION
Support team could not help - recommended service order. I found the solution myself and fixed the door - contact me if anyone has similar problem.
12 REPLIES 12
Highlighted
JUMP TO SOLUTION
Highlighted
JUMP TO SOLUTION
Hey, Having the same or similar issue. The latch is not working and only opening the outer door. How did you get yours to work finally?
kevin
Highlighted
JUMP TO SOLUTION
If you look in the corner(once you separate the latch from door), 1 or two of slits - [  will be visible.  and next to that you will see, gray tabs which slide up and down. Using a thin screw driver, align those tabs next to the slits [ .  once it's aligned, push the latch and it should start operating.. This is sort of temporary fix because with repeated use, it may get stuck again and you will have to repeat the process. Hope this works.
THERE SHOULD BE RECALL ON THIS.
Highlighted
JUMP TO SOLUTION
Highlighted
JUMP TO SOLUTION
what is the purpose of this post - it is not helpful
Highlighted
JUMP TO SOLUTION
Maybe it can be added to the class action lawsuit against Samsung Smiley Happy
Highlighted
JUMP TO SOLUTION
I, too, am having the same problem, on pretty much the same model. I have alrady discovered amd implemented the same temporary fix. It lasted only 1 week before coming apart a seond time.  There's apparantly an issue here.
Highlighted
JUMP TO SOLUTION
I started having this issue this weekend.  Is there any documentation on how to separate the latch from the door?
Highlighted
JUMP TO SOLUTION
