- Mute
- Email to a Friend
11-06-2019 06:04 AM in
Kitchen and Family HubFridge was delivered in June, 2019. Periodically the ice maker flap in the door will cycle continously opening and closing. Nothing seems to reliably work to stop it, opening closing door, pushing ice/water dispenser buttons, tried everything i can think of. Unpluggin fridge waited close to a minute worked one time but not the next as soon as plugged it in flap begins cycling.
Solved! Go to Solution.
- « Previous
- Next »
- Mute
- Email to a Friend
06-01-2020 08:47 AM in
Kitchen and Family HubShare more information on how you disconnected the motor for the flap. The noise is unbearing. I can't concentrate while working in the kitchen.
- Mute
- Email to a Friend
02-29-2020 07:05 PM in
Kitchen and Family HubHello
I believe I have a different model, but same issue.
RF22N781SR/AA
i disconnected the harness as suggested, but still hearing the horrible noise!
any suggestions?
- Mute
- Email to a Friend
03-01-2020 07:44 AM in
Kitchen and Family HubHey, give this link a shot: http://www.samsung.com/us/support/troubleshooting/TSG01001032/
- Mute
- Email to a Friend
03-09-2020 11:08 AM in
Kitchen and Family HubSame issue. Bought one of these from Homedepot. The ice maker door opens and closes constantly. First problem was the installer didn't put the doors on corectly and now the ice maker is broken. The fridge is 2 months old and this is the second service call. I wish I could return it.
- Mute
- Email to a Friend
03-21-2020 01:06 PM in
Kitchen and Family HubI am having this same issue, also my family hub won't connect. Can't troubleshoot and no idea who to call to fix this issue. Any suggestions?
- Mute
- Email to a Friend
4 weeks ago in
Kitchen and Family HubI managed to resolve this (mostly) by removing the front control unit from the door of the fridge, and disconnecting the wire powering the motor on the flap. There's a good youtube video here explaining how to remove the control unit. You want to disconnect the square connect with three wires running through it, directed to the big motor that was spinning the white plastic oblong shape opening and closing the flap. Disconnecting that will stop the motor from working, leaving the flap sealed forever. I think the fridge will still make ice, but you cannot dispense it through the door. The water dispenser still works normally. Overall, only took five minutes and a phillips screwdriver, easier than I expected. I'd recommend this to anyone like me with an out-of-warranty fridge.
- « Previous
- Next »
