My Family Hub Will not open settings
(Topic created: 10-04-2025 01:53 PM)
userYSoTugMgje
Kitchen and Family Hub
I an troubleshooting connection to Samsung Smart Things app and the family hub. It told me to delete the fridge and reconnect. In order to connect I need to open settings to connect but every time I try to launch settings, there is a brief lag and the home page comes up. I am connected to the internet. Apps like Spotify work and play music.
Dan2023
Honored Contributor
You should be adding the frig to the SmartThings app by hitting the plus sign, not in Settings.1759618311153.jpg
userYSoTugMgje
Thanks for responding. When I try to add the fridge in the smartthings app, it tells me to go to the family hub refrigerator and finish connecting through settings on the family hub.
"On your Family Hub's display, go to Settings Connections L Easy Connection, then press the Connect button.
If Connections doesn't appear in the Settings menu, look for Easy connection instead."
Samsung_Moderator
Hi there and welcome to our community! I can understand how aggravating this is and am happy to help you! For this particular issue, you will need to contact our Smart Things Department as they will be able to better assist you 🙂 They can be reached via phone number 866-813-2404 or if you'd prefer, you can check out their community page: https://community.smartthings.com/
