Highlighted
My Refrigerator model RS25566BB evaporator keeps freezing up
JUMP TO SOLUTION
1 SOLUTION
Highlighted
Re: My Refrigerator model RS25566BB evaporator keeps freezing up
JUMP TO SOLUTION
I recommend letting a service technician have a look. Send your full model code and serial number via private message to get started.
3 REPLIES 3
Highlighted
JUMP TO SOLUTION
My freezer  starts warming up but my refrigerator holds temp.  I found the evaporator to be frozen like a block of ice for about 6 inches from bottome.  I used hair dryer to melt the block and Freezer cooled down to minus 4..  after a few days it froze up again.  What could be problem?
Highlighted
JUMP TO SOLUTION
Highlighted
JUMP TO SOLUTION
how can I remove Go Premium Now which just keeps coming back
