My refrigerator ice dispnser Flap keeps opening and closing
(Topic created on: 7/27/20 8:59 PM)
userfTix0HDB4B
Kitchen and Family Hub
My refrigerator is less than 1yr old.  The ice dispenser flap started nonstop running, but it was off and on.  I called the service and still have a few days to have someone.
But now it started continuously flapping.  It won't stop!!!   I turned off the power and backed on, it still cyclying.  Driving me crazy.
Is there anyway I can turn off or reset this ice dispenser area??   I can't have my refrigerator doing this until the service person comes.
SamsungLou
@userJeUe5pvlwi   We are sorry to hear about this. Please send the full model and serial numbers to this PM Link.
userJeUe5pvlwi
Mine is doing the same, fridge is less than 2 months old.  Very frustrated, if this happened only 2 weeks ago I could have purchased a warranty.  Hopefully still covered under manufacturers warranty.
userfTix0HDB4B
It will be covered.  You have a 1 yr manufature warranty from the purchase date.
Now I am waiting for the door replacement in a few days.
hurry up and call the service, that one will never stop.
SamsungLou
IntrepidUSA
I have the same issue with a RSG309AARS/XAA model from 2013, just started today...anyone have a solution? Or just to stop the flap from opening and closing?
userfTix0HDB4B
You need to get that door replaced.  That's the only solution.   I had mine replaced as others had said too.
userFyhL9BcyIP
I have same problem (RF28JBEDBSR/AA).  I had to unplug a connector inside control panel (snap fit).  I still need a permanent solution.  Thanks
