Highlighted
NX58H5600 Gas range emits heat from door vent
JUMP TO SOLUTION
My new gas range does a great job heating and cooking but the oven emit so much heat out of the vent on the left side of the unit that the paint on my cabinets is melting! This can't be normal, what can be done to remedy this?
1 SOLUTION
Highlighted
Re: NX58H5600 Gas range emits heat from door vent
JUMP TO SOLUTION
We are sorry to hear about this. Please send the model and serial numbers to this PM Link.
1 REPLY 1
Highlighted
JUMP TO SOLUTION
