Highlighted
New refrigerator no light in water/ice dispenser area
JUMP TO SOLUTION
Was this brand new Samsung refrigerator designed with no backlighting on the water/ice buttons touch buttons and  no light in the ice/water dispensing area? I can't believe it, our old kenmore had light in both. Is there some way to turn on lights there?
Thank You
1 SOLUTION
Highlighted
Honored Contributor
Re: New refrigerator no light in water/ice dispenser area
JUMP TO SOLUTION
Thank you for this information, regretfully the only LED lights in the dispenser area are on the control panel located just above the dispenser itself. I apologize for any inconveniences caused.
11 REPLIES 11
Highlighted
JUMP TO SOLUTION
Please provide the full model code of the unit so that we can best assist.
Highlighted
JUMP TO SOLUTION
RS25J500DSR/AA
Highlighted
Honored Contributor
JUMP TO SOLUTION
Highlighted
JUMP TO SOLUTION
where can I put request to add led light for water dispenser? Or is there some kind of add-on I can get?
Thanks
Highlighted
JUMP TO SOLUTION
I have a RF28R6201SG and the only time the light comes on is when you press the dispensor, is there a way to make this on continuously?
Highlighted
JUMP TO SOLUTION
R525j50
Highlighted
JUMP TO SOLUTION
Mine stopped working. 6 weeks of use. Delivered 3/30/20.
Highlighted
JUMP TO SOLUTION
I completely agree.  I stand there pushing all over trying to find the ice or the water.  I bought a new house that unfortunatley has all Samsung appliances.  My Whirlpool refrigerator (not an expensive model), had an LED light to light up where the cup goes in and the touch control on the front was lit up as well.  This Samsung is REALLY DISAPPOINTING.
Highlighted
JUMP TO SOLUTION
Samsung has really bad appliances Stay with whrilpool or Ge.
