No Oven or Display, Gas Burners Work
(Topic created: 06-15-2025 05:18 PM)
Members_FF1Gx7n
Kitchen and Family Hub
I have a Samsung NX58J5600SG stove. The oven does not work and the display is blank. The gas burners ignite and work just fine. I have replaced both the control board and the touch panel. Still nothing. Anything else I can check before I call a tech?
GaryB82
Galactic Samsung Care Ambassador
Sounds like you've changed everything the only step now would be to contact Support to have it checked out to see what could be causing the display not to function.
1-800-SAMSUNG
https://www.samsung.com/us/support/contact/
If you've found my post to be helpful, Please like my Comments ✓✓✓.
If my response resolved your issue, please press the Like and ✓✓✓ to Accept as Solution button.
Members_FF1Gx7n
Is there a fuse or electronic breaker anywhere in the back? Is there a power supply that I can check voltages to see if there is even power getting to the control board?
GaryB82
Honestly I wouldn’t know that’s why I recommend contacting Customer Service and requesting a technical inspection. They should have repair manuals available.
