No water dispensing, and unable to remove filter - PLEASE HELP
(Topic created: 11-14-2021 09:39 AM)
randsfun
Kitchen and Family Hub
Hello, I have a home hub fridge (RF56M9540SR) family hub home multi door fridge freezer which no longer dispenses water or ice from the front left door.  I am assuming this is because the filter needs changing, but i am unable to unscrew/remove the filter. PLEASE CAN SOMEONE ASSIST.
Sarah 🙂
1 Reply
SamsungStephanie
Hello, I located the troubleshooting article here- https://www.samsung.com/us/support/answer/ANS00060149/ I would encourage you giving a try. Yes, we do recommend regularly changing the water filter when prompted by the refrigerator for its best performance. If the troubleshooting steps within the article did not help above and you are out of warranty, you can use this link below to find a service center in your area. https://www.samsung.com/us/support/service/locations/
or private message me https://bit.ly/3p4UuiW with your full model and serial number to review service options as that will be the next recommended step and the quickest and best option to resolve this problem
