Highlighted
OVEN Model# NV51K6650SS panel not working,
Just installed a NV51K6650SS single oven. Set the clock, checked out the timer...all working. Attempted to check if oven would heat and the panel went totally black. Tried 60 Sec and ten minutes waiting before breaker reset. The breaker never tripped, just the panel went completely black. Any thoughts?
1 REPLY 1
Highlighted
Re: OVEN Model# NV51K6650SS panel not working,
Did you install the unit or did an installer come out? Does it have the correct voltage to the unit?
