Oven glass door Spontaneous shatter
(Topic created: 07-03-2021 09:29 AM)
userWGFybOGR6u
Kitchen and Family Hub
We bought a new construction home 4 months ago and this morning, about an hour after it was turned off, the glass door spontaneously started cracking and shattering.    The cracking sounds continued for about 20 minutes.   I’m not sure if I can open it or will it shatter all over the place.    Anything I can do?
1 Reply
sandy75
Take a large or multiple sheet of plastic or aluminum foil and place them over the window. Tape them in place on both sides of the window after you take a picture of the window. Call your home insurance and the range manufacturer. Follow their instructions. Do not use the oven!
