Highlighted
Oven won’t heat up and has blinking light
3 REPLIES 3
Highlighted
Re: Oven won’t heat up and has blinking light
Oh no!  Is anything flashing on the panel?  An error message by any chance?
Have you attempted to reset the range by flipping the breaker?
Highlighted
The only thing that flashes is a single blue light. Tried to reset and it didn't work.
Highlighted
Regretfully, if you don't see any error codes and you have already power cycled the unit the next step would be to proceed with service.
Here are some service options:
- If your unit was recently purchased, you can check with your retailer on their return/exchange processes.
- If you have an extended warranty you can reach out to them to have service processed.
- If you're within the one year warranty, you can Private message one of our moderators to have service processed. http://bit.ly/33ipYnO
- If you're OUT of warranty, use the following link to locate a service center in your area:
http://www.samsung.com/us/support/service/location
