useryzWWP0do6R
PowerBot R7040 battery type
I'm suprised that the user's manual does not indicate the chemical type of the battery.  Does it use a Lithium Ion battery?
1 REPLY 1
Re: PowerBot R7040 battery type
Good afternoon. The Samsung PowerBots do use lithium-ion batteries.
