Powerbot won’t turn on after factory reset
(Topic created: 10-24-2021 04:42 AM)
user0gGbywmOWy
Kitchen and Family Hub
I’ve got a powerbot vr7000 tonight it was cleaning and came up with an error that something was stuck in the brush. I followed the manual and then the switch Off on the bottom, removed the jam and turned it back on then put it on the charger.
then when I went to use it again it’s stopped working completely and I check the smart things app on my phone and it’s all offline and not responding to anything.
has this happened to anyone else?
1 Reply
SamsungAl
Have you tried plugging it in somewhere else? Maybe the outlet it was plugged into for some reason stopped working properly? Could you provide the full model code so that I can be of more assistance?
