Highlighted
RF18hfenbsr refrigerator help!!!!!!
A few days ago, the refrigerator started randomly beeping with the doors closed. And the beeps are not the same as the door alarm beeps. Then we found water under the crisper drawers. Did a lot of online searching and came across a post about the drain line being frozen or clogged. Took the back panel off inside the fridge and sure enough the drain line was frozen solid. Took a hair dryer to it and thawed it out. Thought the problem was solved... WRONG. The fridge is still randomly beeping, and now the temperature keeps dropping well below where it is set to. Someone please help me before I take a sledge hammer to this thing. The beeps are driving me crazy!
2 REPLIES 2
Highlighted
Re: RF18hfenbsr refrigerator help!!!!!!
Do you get response at it? what are the temperature that we need to set for each area of the fridge?
Highlighted
I have not gotten a response. The factory settings recommended, -2 for the freezer and 38 for the fridge. Which are what I have it set to and has been set to these degrees for the year that I have owned the refrigerator.
