Highlighted
RF23M8070SG refrigerator leaking a lot of water
My fridge is leaking a LOT of water (at least 5 gallons at a time) out of one of the drains.  It does not collect anywhere in the fridge.  Just over fills the drain pan and then spills on to the floor.  Sounds like either the pitcher autofill or the icemaker autofill just gets stuck open and continuously runs water.  Is this a common issue?  What is the problem?  Is there a fix?
1 REPLY 1
Highlighted
Re: RF23M8070SG refrigerator leaking a lot of water
I am sorry to hear about this. Please send the serial number to this PM Link.
