user1U0WHuTSjJ
RF23R6201SR freezer not working
I got this refrigerator on 8/9/19. Pretty much since day one I'm having an issue with the freezer. Unless it's set to Power-Freeze, nothing gets frozen, no matter what the thermostat reads. I'm having to set it to -8 and power freeze about once a week, since it resets to 0 degrees after a few days. I've followed the troubleshooting instrcutions in the manual but the problem persists.
7 REPLIES 7
Re: RF23R6201SR freezer not working
May I ask who installed the unit and have you checked if the unit is leveled properly?
user1U0WHuTSjJ
The delivery men installed the unit and it is leveld properly - I checked it with my level.
To check if the unit is leveled properly, you would have to look underneath the fridge. Let me know if the leveling wheels are touching the ground.
user1U0WHuTSjJ
Yes, the leveling wheels are touching the ground.
The fridge leveling wheels should be off the ground. The fridge should be slightly raised in the front so the refrigerator is stable. You can level the unit by looking in the link below. You can also reach out to your retailer to see if they are able to assist.
https://www.samsung.com/us/support/answer/ANS00062321/
user1U0WHuTSjJ
I've adjusted the level and will see if it helps.
Sounds good. Please keep us posted.
