RF263BEAESG WATER FILTER part number
(Topic created: 05-10-2021 08:22 AM)
Jaypetrilla1705
Kitchen and Family Hub
For the life of me, I can't find the part # for my Samsung French door Refrigerator RF263BEAESG.  Any help would be forever appreciated.
MsBri1
Neutron Star
Hello, the water filter part number for your unit would be DA29-00020B or HAF-CIN. You can purchase water filters from our part distributor, J & J Parts, at 800-627-4368 or visiting samsungparts.com
1 Reply
MsBri1
Neutron Star
