Highlighted
RF263TEAESR ICE MAKERS IS FROSTING OVER AND BLOCKS ICE
JUMP TO SOLUTION
My ice makers frost over and blocks the ice cubes from dropping. The ice makers also makes a barking sound before dispensing ice.  I have to defrost it (ice maker) at least once a week then reset it. What's wrong, other than being a Samsung? I've seen a lot of bad reviews about their refrigerators.
1 SOLUTION
Highlighted
Re: RF263TEAESR ICE MAKERS IS FROSTING OVER AND BLOCKS ICE
JUMP TO SOLUTION
What do you have your temperature set to? It may be too high and this could be the cause for the frost build-up.
5 REPLIES 5
Highlighted
JUMP TO SOLUTION
Highlighted
JUMP TO SOLUTION
Temp is 0 for the freezer, 34 for refrigerator.
Highlighted
JUMP TO SOLUTION
I have had the same problem with this ice maker for 4 years!  I've had 3 new ice makers put in and it still freezes over.  The repairman told me that even Samsung does not know how to fix the problem.  It is very dangerous to use a hair dryer to unblock the frost.  Samsung has put out a defective product and will not own up to it.  Sounds like a class action lawsuit!
@SamsungTam wrote:
What do you have your temperature set to? It may be too high and this could be the cause for the frost build-up.   -2 degrees.
Highlighted
JUMP TO SOLUTION
@userUprUIAKK0b If you would like further assistance you can reach us by private message.
Highlighted
JUMP TO SOLUTION
The recommended temparature for the fridge is 40 degrees. It is possible this is the cause for the frost bulid up in the fridge. I would also recommend checking the seals around the doors. Moisture forms in the fridge when warm air enters through a door being left open, warm or hot items stored inside, or compartments not sealing properly. Check the alignment of the left side door.
