than1441
RF28HFEDBSR/AA Ice Maker Issue
JUMP TO SOLUTION
I bought this for less than 3 months ago. The date of Manufacture is March 2019. However, Ice Maker did not make any ice and make an only sound. I'm very frustrated.
1 SOLUTION
Re: RF28HFEDBSR/AA Ice Maker Issue
JUMP TO SOLUTION
We would be happy to look into this for you. Please send us a private message to the link.
6 REPLIES 6
JUMP TO SOLUTION
than1441
JUMP TO SOLUTION
Arter I set up again reset and power off. Refrigerator Ice Maker works slowly. Hence, I'd like to check a couple of days. If it will not work again I'll contact again. Thanks.
JUMP TO SOLUTION
Please keep us posted, you are welcome.
user2ZZmvb3Nm7
JUMP TO SOLUTION
I have the same problem.  We paid over $2,000 for this refrigerator and the ice maker has stopped working.  We have reset and defrosted the icemaker countless times.  It works for a few days and then stops working all over again.  It has gotten so bad that we have stopped using the ice maker and now keep bags of ice in our freezer.  This is incredibly frustrating.  I would appreciate direct contact from Samsung on this issue, as it is clearly a flaw.
JUMP TO SOLUTION
@user2ZZmvb3Nm7    We are sorry to hear about this. Please send the model and serial numbers to this PM Link.
user3GBJwnWu4w
JUMP TO SOLUTION
I have had this same probem.  The Service Bulletin stating to seal the compartment with RTV was no help.  I am having to remove the frozen blocks of ice almost weekly.  Other suggestions were to completly unplug the unit to defrost for 24 hours and to do this monthly.  This is a crazy suggestion in my opinion.  Hoping Samsung as decided to do more for customers with this problem.  As this is obviously a design flaw.
