Highlighted
RF28HFEDTSR/AA (3 door) bottom ice make not making ice
I have a water filter on the water line that hooks to the back of the fridge.  I changed it a few days ago and ever since it has not made ice in the lower ice make in the freezer.  The upper ice maker is working fine.  I had the water to the fridge turned off for a couple of days.  Other than having turned the water off for a couple days, it's the same process I've used for the last 4-5 years to put a new filter on the water line.  I changed the water filter in the fridge too, as I always do.  How do I get the lower ice maker working again?  I know there is a reset button on the upper ice maker.  Is there a reset button on the lower ice maker? If there is, it's not in an obvious place.  What if I unplug the fride completely,  would that force the lower ice maker to work again?
1 REPLY 1
Highlighted
Re: RF28HFEDTSR/AA (3 door) bottom ice make not making ice
Found a link that may help. It provides options for any ice maker set up.
https://www.samsung.com/us/support/troubleshooting/TSG01207806/#reset-ice-maker-bottom-freezer
