Highlighted
RF28JBEDBSG/AA Refrigerator Flex Drawer
JUMP TO SOLUTION
Yesterday, my refrigerator was "beeping" all day  (no error messages that I could find).
I can't change the temperature in the "Flex Drawer".  I shut the referigerator off at the Circuit Breaker and the setting changed from "Cold Drinks" to "Meat/Fish".    I then took out the Flex Draw and disconnected & then re-connected the wires.   The drawer changed back to "Cold Drinks", which should mean the draw is at 33 degrees.   The drawer is at about 39 degrees.
The only ligh illuminated on the control panel is the "Cold Drink" light.   I cannot change the setting (nothing happens when I push the "Temp Button".)  No chime, no illumiation ... nothing.  The "beeping" has stopped.
Any ideas?
1 SOLUTION
Highlighted
Re: RF28JBEDBSG/AA Refrigerator Flex Drawer
JUMP TO SOLUTION
The next step would be to proceed with service.  Feel free to send me a private message with your serial number I would be happy to look into some service options for you. http://bit.ly/33ipYnO
6 REPLIES 6
Highlighted
JUMP TO SOLUTION
When you shut the unit off at the breaker, how long was it off? And just the confirm, the beeping has stopped but the display won't change to Meat/Fish?
Highlighted
JUMP TO SOLUTION
Yes, the beeping has stopped.
I only left the refrigerator off, mommentarily.
Highlighted
JUMP TO SOLUTION
I just shut it off again and left it off, for about 15 minutes.
No change.  I still can't change the temperature of the Flex Drawer, but curiously ... the "setting" didn't change.  It's still set for "Cold Drinks".
Highlighted
JUMP TO SOLUTION
Highlighted
JUMP TO SOLUTION
Private Email sent.
Thank you
Highlighted
JUMP TO SOLUTION
I tried to respond to your PM about setting up a Service Call, but the site said I had reached my quoto for "Private Messages".
I would like to set up a Service Call
Thank you
