userbKswnwe1vp
RF28R7201SR Freezer not working
JUMP TO SOLUTION
Just bought the unit today. Plugged it in, set it to the desired temperature, waited a few hours. The fridge cools fine, but the freezer has not gone down a degree. Tried powerfreeze and it went up a degree. Very frustrating as we got it today after having a refrigerator fail. Any advice?
1 SOLUTION
Re: RF28R7201SR Freezer not working
JUMP TO SOLUTION
The retailer didn't installed the unit for you? Where was this fridge purchased at? In many cases, you would need to give you refrigerator 24 hrs to reach its desinated temperature.
1 REPLY 1
JUMP TO SOLUTION
