Range knob stuck in low flame position
(Topic created: 03-23-2021 05:23 PM)
userY5Dvuu01fl
Kitchen and Family Hub
My range won’t turn off. The knob is stuck in the low flame position and won’t budge. (Not the knob itself because when I swap to another knob it still won’t budge.) ive been using wd40 and a plier to try to get the pin under the knob to turn and it won’t. Going on about 90 minutes now. Anyone have any suggestions? Thanking in advance.
SamsungTam
If you haven't already please unplug the range and leave it unplugged. Is the unit showing anything on the display? Please send me a private message with your full model and serial number. http://bit.ly/2tCGnGK
SamsungTam
userY5Dvuu01fl
DM sent!
SamsungLarry
An Accepted Solution has been marked and provided for this thread. The thread will now be locked for further replies. in hopes to keep the integrity of the thread from steering in a non-technical manner. If you have a separate concern, feel free to post again or send one of our moderators a private message with more details. Please note duplicate posts on similar subjects starting 2/1/21, will be removed to keep our community organized and make it easier for our users to find resolutions and needed content. Remember that if you do make a post, please include as many details about your symptoms as possible. Also, make sure that your title is a good summary of the overall situation that's occurring with your product. Thank you for being part of the community!
