HelpinProsper
Re: Ice Off Light won't reset, Samsung French Door refrigerator won't make ice for the lower IM
JUMP TO SOLUTION
I'd like to ask how I can either reset the lower ice maker or turn off the "ice off" light indicator on the door panel.
I have one ice make on the top left door working fine, but the lower unit and the one I typically use the most for hockey water bottles and filling them with ice isn't currently producing ice.
Thanks and very apprecaitive of any assistance you can lend!
Brian
1 SOLUTION
HelpinProsper
JUMP TO SOLUTION
Last night, as fate would have it, I pressed the "off ice" area, which I had done before, but with no response, but last night it let me turn off ice to the top ice maker, then presssing it again, it turned it back on then turned on ice to the lower ice maker and now, both my top and lower ice makers are working!  Thank you for the support, ideas and work!   Appreciated by all!
11 REPLIES 11
JUMP TO SOLUTION
Please provide the full model code of the unit so that we can look into this. Is the Ice Off indicator staying on?
HelpinProsper
JUMP TO SOLUTION
RF323TEDBSR/AA
HelpinProsper
JUMP TO SOLUTION
Yes, the "ice off" indicator is constantly staying on and lit on the front door panel.
JUMP TO SOLUTION
Have you tried unplugging the unit for 10 minutes and then trying to turn off the Ice Off light?
HelpinProsper
JUMP TO SOLUTION
Yes, thanks, I've tried this a few times, so a power cycle essentially is not resetting my lower ice maker to get it working.  What else can I try?  Thanks!
JUMP TO SOLUTION
If you are still experiencing issues with your ice maker, please send us a private message to the link.
HelpinProsper
JUMP TO SOLUTION
JUMP TO SOLUTION
That's great to hear! Happy you were able to get it back up and running. Let us know should you notice the symptoms returning. Smiley Happy
userlTgFdlGhgi
JUMP TO SOLUTION
Hi, I'm having these identical issues.  Please probide me the same solution you gave to this person.  Thx
