Highlighted
Refridgerator Model RF263BEAESG/AA Leaking Water
My refridgerator is leaking water throught the defrost/condensor drain. I have checked the typical solutions that I have found on this forum. I have had the unit for 1.5 years and this has been a rare, but recurrent issue. Usually it resolves itself with only minor inconvenience. This time I had to turn off the water to keep from flooding the kitchen. If the water is on, it runs through the system and out the bottom, like a valve has stuck or failed. Does anyone have suggestions on where sucha vavle might be, or how to get it unstuck?
Thank you in advance for your suggestions.
3 REPLIES 3
Highlighted
Re: Refridgerator Model RF263BEAESG/AA Leaking Water
We are sorry to hear about this. Please send the serial number to this PM Link, and we will look in to this issue.
Highlighted
Serial number <HIDDEN>
Highlighted
Have you checked the water pressure and adjusted it to see if that prevents the water leak?
