Re: RF263BEAESG ice maker freezing up
JUMP TO SOLUTION
How are things with the fridge currently?
userWfGgSvbdwa
JUMP TO SOLUTION
Same issue as everyone else!
userkMdvqaI0HZ
RF28JBEDBSG freezing up
JUMP TO SOLUTION
Hi, could I please have the link to submit a private message to a Samsung technician about my refrigerator repeatedly freezing up? Thank you.
Re: RF28JBEDBSG freezing up
JUMP TO SOLUTION
@userkMdvqaI0HZ You can send a private message here Smiley Happy
userIIwTfKTGuZ
Ice maker in bottom freezer no working. RF323TEDBSR YEAR 2012. Does not have ice build up. Parts mov
JUMP TO SOLUTION
I have a 2012 Samsung fridge with  freezer on bottom. Two ice makers. One in fridge part works fine. One in bottom isn’t working. No ice build up. Parts move freely. RF323TEDBSR. Any ideas?
Re: Ice maker in bottom freezer no working. RF323TEDBSR YEAR 2012. Does not have ice build up. Pa...
JUMP TO SOLUTION
@userIIwTfKTGuZ I would suggest you try these troubleshooting steps and see if they work for you. If they don't fix the issue you're experiencing, the fridge would need to be serviced and you can locate a service center in your area by clicking on this link
userEtAr905qOL
Ice Maker Issues
JUMP TO SOLUTION
We have model RF.SC.2.2. Serial number <Hidden>.
The  water cubed crush controller will not let you switch it from cubed. Stays on that 24/7. On top if that, is making little to no ice. Looks frozen. Have tried unplugging and turning off Icemaker.
usermWQJWYhDPT
Just seal around the ice maker box .
JUMP TO SOLUTION
Samsung_DtNyidQ
Maybe the solenoid is going bad
JUMP TO SOLUTION
userU5Xn7UNj4n
RF263BEAESG
JUMP TO SOLUTION
Ice maker freezing up...water in bottom of frig compartment.
3 year old frig.
Evaporator system on left inside wall below ice maker there is a bulge.
Expensive no good for anything frigerator.
Why are so many people haing issues with Samsung refrigerators?
I beleive cheap made/flood market...high profits!
