Highlighted
Refrigerator and Freezer not holding setpoint - RFG298AARS/XAA
JUMP TO SOLUTION
I notice my freezer was not holding setpoint when my ice cream was thawed yet the digital display set point was -2 and the actual freezer temperature was 20 (measured with a separate thermometer).  The display either did not show the actual temp a few seconds after the -2 setpoint is displayed or it think the freezer is actually -2.  NOT!!
Found the same problem with the refrigerator, set point was 36, actual temperature is 40.  When I checked the unit first thing in the morning the freezer is 0 (set point -2) and the refrig is 40 (set point 36).  Only error code is 88 88 (inverter signal to compressor issue, per samsung Ser Rep but the inverter board red light is steady on, indicating all is normal.  So what do I do?  I don't think low refrigerant would ever reach 0 degrees, ;but it never reaches setpoint of -2.  Obviously the compressor is running. No other error codes.  No frozen evaporator, no sensor errors, no temp errors.  What do you suggest i do next?  Buy a whirlpool?
Highlighted
Ice maker frosted over
JUMP TO SOLUTION
The ice maker on my RF28HFEDTSR/AA refrigerator has frosted over and no longer makes ice. The fridge is about 2.5 years old. How do I resolve this problem?
Highlighted
Re: Ice maker frosted over
JUMP TO SOLUTION
@userReDkAgyHvb Have you tried these troubleshooting steps yet?
Highlighted
JUMP TO SOLUTION
Thanks, however I don't see anything mentioned on that page about removing the ice buildup. There is no ice at all in the bucket and when I removed it to take a look, I found the ice buildup as pictured above. Thanks!
Highlighted
JUMP TO SOLUTION
@userReDkAgyHvb Let's see what else we can do for you. Could you provide the serial number via private message?
Highlighted
JUMP TO SOLUTION
We have the same problem as the above picture.  How can we defrost the ice maker so ice can be made again?
Highlighted
JUMP TO SOLUTION
We have had the same problem. The original ice maker was replaced and we paid for it. This repair is not working since after a few months the same issue is happening again !!!. Its very frustrating after spending the amount of money we did on buying this refrigerator, and then having to pay for a replacement ice maker. It appears that the issue is in the refrigerator and design. We ended up buying this new refrigerator because our older Samsung refrigerator had a problem that according to Samsung was covered by their warrenty. However, since they no longer made that unit, they could not provide the part to repair it and WOULD NOT HONOR THEIR WARRENTY. We then had to buy a new refrigerator and now we have a problem with this Samsung refrigerator and we feel that all we get is a run around from them. Why cant they just admit the flaw and design a solution. Are they afraid of " losing face "?
Highlighted
JUMP TO SOLUTION
For refrigerator RF28HFEDTSR/AA: We turned our icemaker off after 2 years of defrost issues and only use the bottom icemaker. Our fan has continually frozen up and we just defrosted it for the 11th time. I just lost around $350 in food and over the course of the years - probably close to $1500. Samsung refuses to acknowledge the problem. I am now looking for a new refrigerator and will not purchase any further Samsung products due to their lack of assistance.Fan Frozent.jpgFan Frozen2.jpg
Highlighted
JUMP TO SOLUTION
This is a constant problem. I have to scrape the ice off every few days. so frustrating.
Highlighted
Easy fix take out bin as pictured. Lay an absorbant towel...
JUMP TO SOLUTION
Lay an absorbant towel at base of accumulated ice where ice bin was.
Use your hair dryer on high cool setting
to remove existing ice build up.
You should have some ice 1-2 hrs later.
Be patient with both procedures. Samsung has a default in their ice maker design
