userwBlG9aQH5a
Re: ice maker stopped samsung model RF263BEAESR fridge
JUMP TO SOLUTION
Replacement ice maker is $100 I would try that first. They are easy to replace
userlLlN8gaUeg
JUMP TO SOLUTION
Same problem here, and a couple months after the warranty was up.  Did you ever figure out the problem/solution?
Scotties
JUMP TO SOLUTION
We have the same problem. We have pressed the reset button and it worked for a while. Then stopped again a few days later. Pressed reset button again, nothing changed. Then about 4 days later, it started working again on its own. Worked for about a week, then stopped again. Reset doesn't do anything anymore. 3 days later it starts working again on its own.
Our ice maker is not turned off. Tried turning it off and then on again.
We changed the water filter a few weeks ago, and flushed out enough water so there is no air in the lines. Taking out the ice container and putting it back in doesn't seem to do anything different either. It just starts working, and then stops completely for days. This is not very reliable.
What are we missing???
JUMP TO SOLUTION
Are you also using the RF263BEAESR?
Scotties
JUMP TO SOLUTION
YES it is the same model.
JUMP TO SOLUTION
Could you send a private message with the serial number?
userTLLqr0444A
JUMP TO SOLUTION
Did you find any fix? Seems the same thing is happening to mine, one catalyst seems to be taking out the tray, that seems to make it stop again. Then I have to mess with it for days and it will start again.
joeydonuts
JUMP TO SOLUTION
The only thing I do is either reinsert or use a hair dryer to remove the ice buildup. I usually do this about once a month
when ice builds up. Not a permanant solution but it works for me.
It's still a pain.
user6KugwMcNX5
JUMP TO SOLUTION
they need to do a recall on this ice maker im using a blow dryer to melt the ice build up ,about twice a week unreal bad icemaker
userQRDRpbWkQh
JUMP TO SOLUTION
I emptied out my ice bucket as we hadn’t used ice in awhile and it was all frosted and gross.  It was completely empty, without any ice build up.  I held re-set button for 12 seconds and heard a faint motor noise, so per Samsung suggestion I let go.  It did not make any new ice.
My BLUE light (Ice OFF) button is lit (not child lock) and I can’t seem to get it off.
help!  No warranty, and can’t afford service call.
