userBSzg8NafBX
ice maker
JUMP TO SOLUTION
Samsung family hub ice maker freezes over.  Model RF 22M 9581.  Serial <Hidden>.  This model is on your May 2017 service bulletin.  Also it is included in a Class Action lawsuit that is currently in mediation.  Do you have a replacement freezer unit that can be installed or do I have to use bagged ice in the freezer compartment? Obviously, this is a defective ice maker and it should be replaced free of charge.
<Edited to remove private information>
userlFZ5pW6MlE
Flex door rf23j9011 ice maker frozen up, what is the fix for this?
JUMP TO SOLUTION
Our refrigerator’s ice maker has frozen up. It was dripping water for a few weeks and then started not making ice so I pulled the bin out and discovered the ice maker had frozen up and has ice built up all over it. What is the fix for this?
Re: Flex door rf23j9011 ice maker frozen up, what is the fix for this?
JUMP TO SOLUTION
This is something that would need to be serviced. Could you send me a private message with the full model and serial number?
userlFZ5pW6MlE
JUMP TO SOLUTION
I sent the pm where is the solution? This refrigerator was manufactured in October 2018 so it is clearly less then one year old.
user8dnEy1ITyz
Samsung Refrigerator
JUMP TO SOLUTION
Gee, who would have thought that you would have to regularly defrost a modern refrigerator. Ice maker freezes over and the colling coils for the fridge get so caked with ice that the cooling fan rubbs against the iceberg and makes a really irritating noise. Have to take it apart and defrost it about every 3 weeks. Nice job Samsung!
RBC2404
Ongoing problems with ice maker
JUMP TO SOLUTION
For the past year I've had to periodically remove my ice bin and break down the ice building up inside. A month ago the bucket became frozen and unable to be removed. I've tried thawing it out with a hair dryer and I've turned the ice maker off totally but it's still completely frozen. The model number and serial number are in the photo below. This is the second time I've tried contacting you about this issue. The last time I sent a direct message. Hopefully this works better. This is obviously a common problem that many people are having. Please help us.
RBC2404
Honored Contributor
Re: Ongoing problems with ice maker
JUMP TO SOLUTION
Hey there, We sent a reply to you on July 11th at 2:16 PM but haven't gotten a response from you. Please feel free to follow up with us privately at your convenience.
userh6nKf8XkiD
JUMP TO SOLUTION
Hello @SamsungMod23  ,  Own a Samsung RF28JBEDBSR/aa
I too am purplexed by how much maintenance is required to keep the ice maker working! Every 1 - 2 weeks it will jam as described in numerous online postings.  Need to pull tray out and clear  jammed ice cubes from front to back.  While it does not require a jack hammer it does require a lot of brute force.  Sometimes scrapped knuckles as a result.
Fortunately I have a +15 year Jenn-Air downstairs still producing tons of ice.  The ice maker is not the reason we purchased the Samsung either BTW.
So is there a fix for this from Samsung?  Seems to be a HUGE design flaw as the ice maker does produce ice but jams often when transferring to the tray below and then stops prodcuing until you free up the jam.
JUMP TO SOLUTION
For assistance with your concern, you can send us a private message to the link with your serial number.
user98uvO2jAnC
Ice Bin Auger making squeaky noises
JUMP TO SOLUTION
Hello All!
Refrigerator model is RS265TDRS
Need some advice.  The ice bin started making a bad squeaky noise when I try to dispense ice other day. I took the bin out, dumped the ice but it was still making the squeaky noise even ehen I reached into the bin and turned the auger hook with my hand. I let it thaw out completely, I washed it, I even used a plastic dropper to put some vegetable oil between the washers on the auger axis (there are washer between the blades with teeth) nothing worked. It still squeaks.
Should I take it apart and replace the washers or something? Any help would be appreciated
