Highlighted
Samsung Refrigerator
JUMP TO SOLUTION
Gee, who would have thought that you would have to regularly defrost a modern refrigerator. Ice maker freezes over and the colling coils for the fridge get so caked with ice that the cooling fan rubbs against the iceberg and makes a really irritating noise. Have to take it apart and defrost it about every 3 weeks. Nice job Samsung!
Highlighted
Ongoing problems with ice maker
JUMP TO SOLUTION
For the past year I've had to periodically remove my ice bin and break down the ice building up inside. A month ago the bucket became frozen and unable to be removed. I've tried thawing it out with a hair dryer and I've turned the ice maker off totally but it's still completely frozen. The model number and serial number are in the photo below. This is the second time I've tried contacting you about this issue. The last time I sent a direct message. Hopefully this works better. This is obviously a common problem that many people are having. Please help us.
RBC2404
Highlighted
Re: Ongoing problems with ice maker
JUMP TO SOLUTION
Hey there, We sent a reply to you on July 11th at 2:16 PM but haven't gotten a response from you. Please feel free to follow up with us privately at your convenience.
Highlighted
JUMP TO SOLUTION
Hello @SamsungLarryK  ,  Own a Samsung RF28JBEDBSR/aa
I too am purplexed by how much maintenance is required to keep the ice maker working! Every 1 - 2 weeks it will jam as described in numerous online postings.  Need to pull tray out and clear  jammed ice cubes from front to back.  While it does not require a jack hammer it does require a lot of brute force.  Sometimes scrapped knuckles as a result.
Fortunately I have a +15 year Jenn-Air downstairs still producing tons of ice.  The ice maker is not the reason we purchased the Samsung either BTW.
So is there a fix for this from Samsung?  Seems to be a HUGE design flaw as the ice maker does produce ice but jams often when transferring to the tray below and then stops prodcuing until you free up the jam.
Highlighted
JUMP TO SOLUTION
For assistance with your concern, you can send us a private message to the link with your serial number.
Highlighted
Ice Bin Auger making squeaky noises
JUMP TO SOLUTION
Hello All!
Refrigerator model is RS265TDRS
Need some advice.  The ice bin started making a bad squeaky noise when I try to dispense ice other day. I took the bin out, dumped the ice but it was still making the squeaky noise even ehen I reached into the bin and turned the auger hook with my hand. I let it thaw out completely, I washed it, I even used a plastic dropper to put some vegetable oil between the washers on the auger axis (there are washer between the blades with teeth) nothing worked. It still squeaks.
Should I take it apart and replace the washers or something? Any help would be appreciated
Highlighted
Samsung refrigerator ice maker and icing problems
JUMP TO SOLUTION
We have a 2 year old french door refrigerator.  The ice maker has stopped working, and was barely working in the past 6 months.   When i consulted with the online chat, the best answer i got was to call a repairman because it was out of the warrenty.  Ok well i guess i can do that, not happy about it however not only is the icemaker not working now  yesterday i pulled out the bottom drawer in the fridge to get something out, and when i did,  ice sheets came flying out from under the drawer and now i have a nice little cut on my toe from the ice hitting it!    HELP!
Highlighted
Re: Samsung refrigerator ice maker and icing problems
JUMP TO SOLUTION
We are sorry to hear about this. Please send the model and serial numbers to this PM Link.
Highlighted
Refrigerator Model RF261BEAEWW Freezes
JUMP TO SOLUTION
We purchased our refrigerator on 01/04/2014.  It has been serviced twice for the same issue in four years prior to the end of the extended warranty.  The back of the refrigerator, behind the panel, keeps freezing and building ice.  When it gets to a certain volume of ice, the fan starts to hit it, causing a lot of noise.   We have defrosted it twice since January and it continues to freeze up.   We called several appliance repair companies and most won't service Samsung products.   We have been told this issue is a known design flaw but there hasn't been a permanent fix identified.   Has anyone had this issue and have you found a resolution?
Thank you.
Highlighted
Ice maker won't reset. No water upper or lower ice maker.
JUMP TO SOLUTION
No water is flowing to either the upper or lower ice maker on my Model RFG298AARS Samsung french door refrigerator.  I unplugged it, removed all contents and blew a fan inside open doors for 6 hours.  So, it should be thawed if that was the problem.  I also tried pushing the reset button on the upper ice maker but no "ding".  What should I try now?
