userufVCH15OIZ
Refrigerator Not Cooling
Need help with my 4-door flex zone refrigerator. Model Number RF28K9380SR.  It is right at 3 years old.  Noticed a humming noise late last week. After consulting the manual, I noticed that it was right up against the wall and moved it away from the wall. Humming stopped (apparently though it completely stopped running!)  Last night came home to water leaking out of water/ice dispenser. This morning I noticed the fridge did not seem cool and the stuff in the freezer was thawing out.
3 REPLIES 3
Re: Refrigerator Not Cooling
We are sorry to hear about this. Are you seeing any errors or messages on the display?
userufVCH15OIZ
None so far.  Is there a way for us to do something to get an error code, like run a diagnostic?
The diagnostics are fairly complex. You can get them from the service manual, which is available from www.samsungparts.com. If you will send the serial number to this PM Link, we can check for any available warranty status.
