Highlighted
Refrigerator RF22K9381SG/AA issues, Ice maker again, freezer functioning correctly
Ice maker not functioning again, Repaired once. Back to the Ice dams, and melted ice.  Now the freezer is not working correctly.  FIrst, I can hear the unit running continually.  The light is not on in the Freezer but is on in the rest of the fridge.  So, for instance, on the display, the freezer shows 24 deg, and the fridge 35.  I unplugged it and waited 10 sec and plugged it back in and now the freezer showed 1 deg, fridge was the same.  From 6 months after we bought this thing, we have had nothing but issues.  Not just the items above, but the showcase door broke too.  This should not be happening on a $4200 fridge.  I have seen so many disscussions on the ice maker, I can not believe there is not a recall on it.  The rest of the issues, so dissapointed in this purchase
2 REPLIES 2
Highlighted
Re: Refrigerator RF22K9381SG/AA issues, Ice maker again, freezer functioning correctly
I am sorry to hear of your frustrations. Would you please send a private message with the serial number so I may look into this for you? http://bit.ly/2XERsky
Highlighted
Well...  Samsung called within a week and had a repair shop come out and fix the issues.  They did stand behind thier product!!  Ice maker is making ice like a champ.  The temp was caused from a magnet in the plastic housing that goes around the hinge on the bottom left.  The cover fell off and the magnet did not make the read switch.  Everything is working great now.  I cant say enough with the response.
