userlbGK5OAPj3
Refrigerator RF263BEAESG/AA-Ice Maker Problem
JUMP TO SOLUTION
My 1.5 year old Samsung refrigerator icemaker stopped dropping ice.  The tray fills but the ice will not automatically drop.  If the reset button is manually pressed, the motor starts, the ice drops and the tray refills.  Then a chime sounds.  The temperature is set at 2 degrees.  Water pressure is good and the filter is new.  Ideas?
1 SOLUTION
userlbGK5OAPj3
Re: Refrigerator RF263BEAESG/AA-Ice Maker Problem
JUMP TO SOLUTION
Repairman came today and replaced the icemaker.  It is working as it should.
9 REPLIES 9
JUMP TO SOLUTION
If ice only drops from the ice maker if the test/reset button on the ice maker is pressed, verify that the Ice Off icon is not illuminated on the display panel. When Ice Off is enabled, the ice maker is turned off. However, when pressing the test button, the ice maker will harvest any ice that is in its ice tray.
To verify that the control panel is working properly, enable and then disable the Ice Off function.
On rare occasions, Ice Off may be enabled but the display indicator no longer functions correctly. In this case, service is required.
userlbGK5OAPj3
JUMP TO SOLUTION
Ice-off works properly and is extinguished.
JUMP TO SOLUTION
Out of curiousity. have you tried removing the water filter and then getting ice?
userlbGK5OAPj3
JUMP TO SOLUTION
Yes.  No change with or without filter.
JUMP TO SOLUTION
Could you send us a private message with the serial number?
userlbGK5OAPj3
JUMP TO SOLUTION
userWyphvOAhwi
JUMP TO SOLUTION
Saw your problem with the ice maker.  I'm having the same problem.  Did you have to call a repairman or have the ice maker replaced?  Thank  you.
userqdobouvo70
JUMP TO SOLUTION
Mine is having same problem. I have thawed it out several times and seems to work for awhile then stops again  i think mine may freeze up  gets excess ice build up. Not sure if i should just replace it
user0z1kmAyfLv
JUMP TO SOLUTION
