Highlighted
Refrigerator RF28R2701SR Default Wifi Password not working
JUMP TO SOLUTION
After getting this I was able to set this up for the first time. However after power to the refrigerator was lost for a few mins, it was showing offline in the app. After trying for several hours to get this to reconnect decicded to just go back through the setup again, I have to sometime do with other iot at the house. However when trying to set this up again with the app it can no longer connect to the refrigerator the first time. So when trying to add the refrigerator back to smartthings app it stops on connecting to refrigerator and fails. It then tell me that it can't connect and to try it manually using the 1111122222 but that gives me a authincation failure. Any help would be greatly apperatied.
1 SOLUTION
Highlighted
Re: Refrigerator RF28R2701SR Default Wifi Password not working
JUMP TO SOLUTION
I completely understand how frustrating this must be. I recommend reaching out to our Smarthings Department at 1-800-Samsung concerning this.
9 REPLIES 9
Highlighted
JUMP TO SOLUTION
Highlighted
JUMP TO SOLUTION
I contacted Samsung and they told me to try the smart thing team. but that wouldn't be open until Mondays morning.
Highlighted
JUMP TO SOLUTION
I'm having the same issue, what did the fix end up being?
Highlighted
JUMP TO SOLUTION
I have same problem. I failed to add mt refrigerator to smartThings. What is the solution?
Highlighted
JUMP TO SOLUTION
What is the final solution?
Highlighted
JUMP TO SOLUTION
I just experienced when the neighborhood lost power. So you didnt get an answer?
Highlighted
JUMP TO SOLUTION
After talking with smart home team they had someone come out and replace the wifi module and it was fine after that. Tech said that he had not seen that before but looked my the module was just bad.
Highlighted
JUMP TO SOLUTION
Hello,
It does not make any sense as i am having the same problem with my brand new Refrigerator, once i thought i was able to connect but it went out with an error and i tried the same password which is 1111122222 and it is not working anymore. I tried to unplug the power cable as i thought it would reset AP but did not work either. Any help on this other than replacement?
Thanks.
Highlighted
JUMP TO SOLUTION
I am afriad that I was unable to find anything other than having the module repalced for my issue. Once replaced it has been fine.
