Highlighted
Re: Refrigerator auto-fill water pitcher leaks
JUMP TO SOLUTION
I am having the same issue with my pitcher. I have tried resetting the lid multiple times and it leaks every time we use it. Has anyone found a way to fix this? I bought my fridge about 5 months ago.
Highlighted
JUMP TO SOLUTION
@userZe7j4TCi9B I would like to have one sent out to you! Can you send me some photos of the leak as well as the full model and serial number via private message?
Highlighted
JUMP TO SOLUTION
Having the same issue, leaks a stream from the seal when you pour.  Only use it over the sink now.
Highlighted
JUMP TO SOLUTION
This didnt work
Highlighted
JUMP TO SOLUTION
Hi, I bought this fridge model: RF28R7351SG/AA about 4 months ago, and the pitcher is leaking water right where the lid meets the container under the nozzle. Has samsung created a new pitcher that doesn't leak?
I would like a new one since this should be under warranty still. Thanks!
Highlighted
JUMP TO SOLUTION
Can I have your full model code and serial number via private message?
Highlighted
JUMP TO SOLUTION
No they haven't fixed it yet. A few months ago i finally got them to understand the problem and they sent me a new pitcher, it did the same exact thing. Today, I am trying again. They want me to put in a repair request again. That doesn't help. It makes you try to schedule a home visit. I don't need that. I just need a pitcher that works. how did they mess this up so badly?! This pitcher was what differentiated this frig and they got it wrong?!?!
Highlighted
JUMP TO SOLUTION
My autofill pitcher also leaks; please advise if there is a replacement available that does not leak:
Model #RF28R7351SR
Built March 2019
Highlighted
JUMP TO SOLUTION
Please send the model and serial numbers to this PM Link.
Highlighted
JUMP TO SOLUTION
I'm also having this same issue where the pitcher leaks. I've also tried resetting seal but did not work. Is there a new pitcher that doesn't leak yet?
