Highlighted
Re: Refrigerator Auto Fill water pitcher leaking
JUMP TO SOLUTION
I'm sorry to hear that, can you send me a private message with your full serial number so that we can look into all options possible?
Highlighted
JUMP TO SOLUTION
I have this same issue and my refrigerator is just a few months old?
Highlighted
JUMP TO SOLUTION
Same problem. They sent me a replacement pitcher and the same thing happened. Very frustrating.
Highlighted
Auto fill water pitcher leaking
JUMP TO SOLUTION
My water pitcher is leaking in the front below the pour spout around the seal. It is put on correctly and I have tried several times.
Highlighted
Re: Auto fill water pitcher leaking
JUMP TO SOLUTION
I'm sorry to hear that, can you send me a private message with your water pitcher leaking so that I may look into this?
Highlighted
Re: New water picher leaking AGAIN
JUMP TO SOLUTION
Ours leaks also! Bought frig early January.
Hey Support.. "many" of us have the "same" problem. Probably a good time to take action, fix the flaw and send out new water pitchers that are leak proof.. to all who have purchased within the last 12 months.
Highlighted
JUMP TO SOLUTION
To fix this take off the gasket and replace with a rubber band and then put the gasket back on over the rubber band. This will make the gasket thicker and will stop the leak. At least this worked for me.
Good Luck
Highlighted
Samsung Auto-Fill Pitcher leaking/defective
JUMP TO SOLUTION
I just purchased my samsung fridge and everytime i pour water out of the auto-fill pitcher it leaks from the top. This seems to be a common topic based on multiple other threads with the same issue. How do we contact Samsung support to cover a replacement under warranty?
Top is secured, it seems to be an issue with the gasket/seal or perhaps the seam on the plastic itself.
Highlighted
Re: Samsung Auto-Fill Pitcher leaking/defective
JUMP TO SOLUTION
How do you wash the pitcher? Can I have your full model code and serial number via private message?
Highlighted
JUMP TO SOLUTION
I have same issue with a leaking pitcher. How do I contact Samsung for replacement under warranty? @SamsungLarry
