Highlighted
Re: Refrigerator auto-fill water pitcher leaks
JUMP TO SOLUTION
I'm sorry to hear that, can you send me a private message with your full model and serial number and pictures of the water pitcher leaking?
Highlighted
JUMP TO SOLUTION
I've sent a PM with all the info and pictures and have still not received a response.
Highlighted
JUMP TO SOLUTION
@usercb1bvWkMfO    I apologize, we have not received a private message from you. Please resend your information to this PM Link.
Highlighted
JUMP TO SOLUTION
resent to the PM Link as requested
Highlighted
JUMP TO SOLUTION
I have had the same issue since I got my referigerator.  The replacement part is $90!  Quite a lot for a plastic container... and it seems like others that received replacements had similar issues as well so I don't want to spend that much money on an already expensive refrigerator.  I am out of warranty but it has happened since i got the appliance.  (only 2 years ago).  I wish Samsung would resolve this issue...
Highlighted
JUMP TO SOLUTION
I got a replacement and it does the same thing, leaks all over my feet and floor! So frustrating!
Highlighted
JUMP TO SOLUTION
This seems like a big problem.  I just purchased the fridge and am having the same problem.  It seems like the problem is that seam is in the front of the pitcher.  Is Samsung planning on redesigning it?
Highlighted
JUMP TO SOLUTION
I received my brand new Samsung refrigerator 2 days ago (RF23R6301SR/AA) and I am having the exact same issue. I have tried to dry the seal and re-seat it multiple times... neither solution has worked.
Highlighted
JUMP TO SOLUTION
Only had our new fridge for about 3 months.  The pitcher has leaked from the front since day 1.  It just seems worse now.  I noticed that compared to the back, it has a very slight bow at the seal.  Probably just enough to cause the dribble.  Looking at other posts, it seems this is a common defect.  How do I replace just the clear pitcher?
Highlighted
JUMP TO SOLUTION
Could you send me a private message with the full model and serial number?
