Highlighted
Re: Refrigerator auto-fill water pitcher leaks
JUMP TO SOLUTION
Sent you a private message.
Highlighted
JUMP TO SOLUTION
@sylvia51 Thank you! I will follow up with you there.
Highlighted
JUMP TO SOLUTION
I will send you a message since this is happening now to my second pitcher I received as well.
Highlighted
JUMP TO SOLUTION
What's the solution?  I just recieved my new pitcher and lid, and it still leaks when pouring.  Is there going to be a updated pichter that doesn't leak. After what we all paid for these fridges I won't live with a leaking water pitcher.
Highlighted
JUMP TO SOLUTION
I have the same problem with the leaky pitcher. Please help.
Highlighted
JUMP TO SOLUTION
So that we can look into this further can we have your full model and serial number in private message
Highlighted
JUMP TO SOLUTION
My water pitcher leaks, as well. Attempts to keep it from leaking haven't been successful.
Highlighted
JUMP TO SOLUTION
I am having this issue as well
Highlighted
JUMP TO SOLUTION
Can I have your full model code and serial number via private message?
Highlighted
JUMP TO SOLUTION
I have the same issue. Fridge is only 4 months old but the water pitcher has been leaking in the front since day 1. Has a new pitcher been designed yet??
